Maxwell Render
It is currently Wed May 22, 2013 3:01 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Tue Jan 31, 2012 9:35 pm
brodie_geers wrote:
Once you edit your focal length to be something like 35mm in SU, from then on it should display in mm. Are you saying that isn't the case?
-Brodie
No, I think he's trying not to lose his camera position/view.
Best,
Jason.
_________________
My Tutorial Video Series: Maxwell Render 2 - SketchUp to Maxwell Workflow - ZBrush 4 - Corel Painter 12 Advanced - Substance Designer 2.1
Top
 Profile
PostPosted: Tue Jan 31, 2012 9:42 pm
If you just want the answer without doing any math you can use this Dynamic Component I made for calculating... make sure to bring it in as a component rather than opening it.
AOV calculator.zip
Best,
Jason.
_________________
Top
 Profile
PostPosted: Tue Jan 31, 2012 9:54 pm
Half Life wrote:
Try dropping this into the Ruby Console
Code:
Sketchup.send_action(10624)
I have to say, you're on your own if you use this (it is undocumented, and afaik, Windows-only). If he just wants to know the focal length, here is the code to get it:
Code:
Sketchup.active_model.active_view.camera.focal_length
_________________
Next Limit Team
Top
 Profile
PostPosted: Tue Jan 31, 2012 9:57 pm
Brodie, it is true that inputting in mm will change my view accordingly. However, I was simply trying to determine what my current FL is (not change it). [edit: thanks JD for that code. Just what I was looking for].
What FL would you recommend for a shot like this?
[ETA again: FL currently at ~43.5 according to JD's code.]
_________________
SU 8 Pro
Rhino 4.0 SR9
MR 2.6.1
Top
 Profile
PostPosted: Tue Jan 31, 2012 10:00 pm
The reason I created the calculator in the first place was to know what the "normal" focal length (and the 35mm equivalent) was for any given aspect ratio -- because IMO it's best to stay in that range.
But more than that there is the issue of vignetting (darkening around the edges) which comes on stronger at small focal lengths.
Best,
Jason.
_________________
Top
 Profile
PostPosted: Wed Feb 01, 2012 7:19 pm
It's just a matter of balancing out your light. Here's some quick examples (Screen shots/setups are shown in Max, but you should get the just of it)
Daylight:
Here's the physical sky setup:
Here's the emitters (lights) placed in the scene:
Here's the render with iso settings and what not to show how light is balanced:
as well as some different versions:
IBL (Image Based Lighting):
Here's the IBL setup:
hope this helps!
Top
 Profile
PostPosted: Thu Feb 02, 2012 8:41 pm
That was super helpful, thanks! How long did it take you to do that?
_________________
SU 8 Pro
Rhino 4.0 SR9
MR 2.6.1
Top
 Profile
PostPosted: Thu Feb 02, 2012 11:51 pm
glad it helped.... it took less time to do that than it did trying to confuse you with words... less talk, more do.... :)
Top
 Profile
Search for:
Jump to:
