Maxwell Render
It is currently Tue May 21, 2013 10:38 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Sun Jun 26, 2011 9:07 pm
Update 29/11/11: Just a little animation of my favourite car:
http://youtu.be/10vstbbIJ4c
Update 16/11/11
I've been wanting to update this for a while, here's some recent work. Some aren't particularly Maxwell-y, but I always use my favourite render engine.
Escher inspired:
Some George Hart inspired work:
Some Pythagoras trees:
Hilbert cube! (One of my favourite fractals):
Some jewellery I did over the summer (for practise):
Koch snowflake:
Koch Icosa:
Inverse menger sponge:
And finally some interlocking tetrahedra:
Hi everyone, I decided to finally show off some work that I've done that's not university based, all the images here were created purely for fun/experience. These have all been created since October 2010 using Maxwell.
--- G E O M E T R I C ---
I lot of my work recently has been inspired by the legendary geometric work of Torolf / Jotero. Some of these models were made with Cinema 4D, some with Paracloud GEM.
This image features a flower profile swept around a fourier knot, to show the thin sections I used the blue rubber SSS preset. With thanks to 3D-meier for the formula.
This image was an adaptation of the cornell box (that ceiling made it take quite a while to render). Maybe someone could answer why the area behind the glass sphere looks so dark. The glass was as clear as I could make it and the scale is correct (for a cornell box). Is the glass just refracting the available light away?
This image was just experimenting with the cornell box and complex geometry face orientation (knot).
The same model as above with a glass knot.
A simple subdivided cube with some deformation and an atom array.
This was a test of dispersion. I realised after I made this I could have used PhotoShop to copy the image into the pattern instead of rendering it.
This was a test of modelling and bump mapping. (Can't remember which HDRI I used, sorry).
My first Klein bottle.
The lighting isn't perfect in this one but it's a menger cube with cross bracing in GEM.
This is a variation on a menger cube and uses the wizard gold material.
A menger cube with spheres.
A menger cube deformed to make a torus, with a spherical emitter in the middle for good measure.
This image was created using a menger cube of bevelled cubes. I used the low quality glass wizard material but the green transmittance colour didn't look that good, so I changed the hue in PhotoShop.
This is one the physics fans like me might like, a test of dispersion in a triangular prism. I used the 'narrow slit light box far away' method. This is SL25 and I don't know what would have to be done to make it clear up any better, if it ever could.
This was a test of modelling. The pattern is a sine-sine wave. This image involved some post work in Alien Skin Exposure.
This was a test of modelling inside GEM.
This is a mobius loop modelled in Cinema then GEM was used to add the detail.
The next 3 images were inspired by Structure Synth but made using mograph.
These were modelled in TopMod as dispersion examples.
This is the same model as above but with smoothing.
This was a fingerstar modelled in TopMod, given a glass material with a low Nd value and then an emitter was placed above it to make the pattern on the floor.
This was a quick modelling test.
--- C H E M I C A L ---
This image was a test of using near perfect mirrors to create the illusion of infinity. The molecule is adrenalin. This was rendered using the Ranch when they had they're special 5 minute offer and reached SL19 in that time.
This was a test of bokeh as well as a cool background. The model is vitamin B12 and is from 3D Printables
--- P R O D U C T ---
This was a test for using Maxwell to render lighting products. A large spherical emitter is inside a rounded cube which has the tracing paper thinSSS preset applied.
The same model as above with the lights off.
--- A U T O M O T I V E ---
To practise my automotive rendering I used a model from Xtrm3D. This was my favourite out of the several that I did. Some post work using Alien Skin Exposure.
This was another automotive rendering test. Model courtesy of http://xiiid.deviantart.com/
This is my latest and most complete car to date. I let this reach SL20. Some post work in Photoshop & Exposure.
--- O T H E R ---
This was a test of which sampling level images would need to be rendered to when I printed them at home. The image was rendered at A6 resolution in sampling level steps of 2, as annotated. When combined and printed, there was no visible difference between SL12 and SL14, demonstrating that when destined for print on my home printer anything above SL12 was overkill. The model was created in Cinema 4D using a mograph cloner with the Stanford Bunny and a sphere. The HDRI used was custom.
These images were made when I first started experimenting in-depth with stereoscopy and SSS. Model courtesy of http://www.cs.caltech.edu/~njlitke/meshes/collections/hhoppe/
Edited 13th July with some new work. Next I'll add some animations! Thanks for viewing and I welcome all constructive criticism and feedback!
_________________
My Maxwell Render Tutorials
University of Brighton, UK
http://www.coroflot.com/James_Coleman
@JColeman_Design
Top
 Profile
PostPosted: Sun Jun 26, 2011 11:08 pm
Tremendously beautiful set of images! Very nice!
_________________
Next Limit Team
Top
 Profile
PostPosted: Mon Jun 27, 2011 3:34 am
i must concur. a lot of fun for the eyes....
Top
 Profile
PostPosted: Mon Jun 27, 2011 7:17 pm
Thanks for posting all of those! Fun to look at!
_________________
Brian Looney
Maxwell + RealFlow
http://lunatic-studio.com/
Top
 Profile
PostPosted: Tue Jun 28, 2011 3:11 pm
I agree, very fun gallery. Nice to see a collection of more abstract images being posted. Good work. :D
_________________
Visario / web > blog > twitter > youtube > gallery
Top
 Profile
PostPosted: Tue Jun 28, 2011 3:22 pm
wow, so many interesting good renders. :o
_________________
many limits team
:: twitter :: Gallery :: My 3D products :: ...and ::
Top
 Profile
PostPosted: Thu Jul 07, 2011 12:42 am
fantastic work James!
_________________
Visit simkits.com simulated aircraft instruments and complete flight decks
Top
 Profile
PostPosted: Thu Jul 07, 2011 11:22 am
great pictures!
I love the vitamin B12 picture that loosk so simple, yet so stunningly beautiful and stylish.
the smoothed glass sphere thingy and the structureSynth things are nice as well!
How did you you do the torus knot in Cinema? any special formula or plugin for that object? I loved playing with it in 3dStudio (before it got Max) and missed this thing in Cinema...
_________________
Cinema R14 Studio, MoI 14+2
Top
 Profile
PostPosted: Thu Jul 07, 2011 9:41 pm
nice exemple !
_________________
Concentrateur d'idées...
I'm bad in 3d work but I express myself in pictures
And i am bad in english olso . Bad, bad.
viewtopic.php?t=19130
my music
http://www.soundclick.com/bands/page_mu ... dID=948994
Top
 Profile
PostPosted: Fri Jul 08, 2011 8:13 pm
My thanks to everyone for their compliments.
The knot in that example is from Cinemas own material preview. In OSX the file is found in MAXON>CINEMA 4D R12>library>materialpreview
_________________
@JColeman_Design
Top
 Profile
PostPosted: Mon Jul 25, 2011 6:00 pm
I recently made an animation for a friend: YouTube link
The model was delivered as .stl components from SolidWorks, everything else was done in Cinema 4D (except the titles and music, which was Photoshop and Garageband respectively).
I'd like to ask a favour: If there's anyone reading this who's done similar work, can they give me an estimate of how long it would take them? I'd like to know how I'm doing. (Answers in a private message please).
_________________
@JColeman_Design
Top
 Profile
PostPosted: Wed Nov 16, 2011 11:23 am
Updated 16/11/11 with some recent work, thanks for looking!
_________________
@JColeman_Design
Top
 Profile
PostPosted: Wed Nov 16, 2011 3:50 pm
Good job! Really like the clean look everything has.
_________________
Top
 Profile
PostPosted: Wed Nov 16, 2011 11:04 pm
New pieces are really enjoyable.
_________________
Next Limit Team
Top
 Profile
PostPosted: Thu Nov 17, 2011 12:11 am
very good work, very inspiring!
cheers
markus
_________________
3 d w o r k s   v i s u a l    c o m p u t i n g
macpro, 2x6cores@2.66 ghz, 48gbyte ram, ati 5870, osx 10.8.2
using and testing maxwell with form-z, lightwave and modo.
Top
 Profile
Search for:
Jump to:
