Maxwell Render
It is currently Wed Jun 19, 2013 10:10 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Grass Angle Mapping Tool
PostPosted: Mon Jun 18, 2012 7:40 pm
The new Maxwell grass system (in the 2.7 update) is very cool, but the angle mapping option is a bit complex.
In order to simplify the task of making and compiling angle maps for the Maxwell grass system I made the following Substance which can do some unique things (and is completely free): https://dl.dropbox.com/u/41250852/Maxwell_Grass_Angle_Mapping.sbsar
As you can see it is a very small file (under 3 kB) but it has a wide array of options that will allow you to do any of the following:
  • Auto creation of Swirl Maps or Radial Maps (your choice)
  • Input of custom greyscale maps for any of the RGB channels (to create your own angle patterns)
  • Auto clump generation (this can be randomized by changing the seed value) -- which is the real point of this Substance
  • Clump Threshold -- this is based off the green input channel (so you can have any custom shaped clumps you desire)
  • Maximum and Minimum Clump Size (to control the randomization a bit)
  • Number of Clumps
  • Minimum Height Angle (90 degrees being straight up and 0 degrees being lying flat on the ground)
  • Length map (derived from the Green channel)
  • Clamping (threshold position, softness and inverting) of each RGB channel
  • Preview of each RGB channel (to see exactly what is happening to each channel when clamping)
  • Clamping operations for the matching density map (invert was not included because you can do this easily in Maxwell)
  • Output resolutions up to 2048 x 2048 dynamically
The most powerful/unique aspect of this tool is the clumping aspect (which works in a similar fashion to the Image Hose tool in Corel Painter) -- this can be customized to create some really nice random effects that would be very difficult to get any other way. I would highly recommend creating a greyscale map to represent the height of a clump (think of it like a displacement map) and using it for the green channel input, which when combined with the clumping function can generate some nice effects. The default settings will give this result on a 1m x 1m plane (normalized UVs):
The only grass setting I changed here was to increase the density to 50,000... everything else is the work of the maps. I personally like to stack several grass modfiers on the same geometry with the same maps (using different seed values) and variations of the grass material (dried, green, etc.) to increase the naturalism.
You'll need to download the Free Substance Player app to render out these textures (assuming you are not using 3DS Max or Maya, which support Substances directly).
If you find this tool helpful, please add a +1 to the Maxwell Support for Substances feature request thread here.
You can get my "green grass" MXM material I used here: https://dl.dropbox.com/u/41250852/j_greengrass_base.zip
If you have any questions please PM me.
Best,
Jason.
_________________
My Tutorial Video Series: Maxwell Render 2 - SketchUp to Maxwell Workflow - ZBrush 4 - Corel Painter 12 Advanced - Substance Designer 2.1
Top
 Profile
PostPosted: Sun Jul 01, 2012 7:45 pm
Here's a video about using this Substance with the Maxwell Grass system -- also, I've updated the Substance as well, so if you have an older version please re-download.
Best,
Jason.
_________________
Top
 Profile
PostPosted: Wed Jul 04, 2012 4:44 pm
Looks nice.
Thanks for the share.
I have to try it later. :)
_________________
many limits team
:: twitter :: Gallery :: My 3D products :: ...and ::
Top
 Profile
PostPosted: Tue Jul 17, 2012 2:28 am
Hi Jason,
Thanks so much for sharing the grass clumping Substance. It's been a great incentive for getting into the Substance player which seems to have so much potential. I'm looking forward to exploring it further :-)
Andrew.
Top
 Profile
PostPosted: Fri Jul 20, 2012 11:16 am
Tanks Jason for the share !
_________________
Cinema4D for Architecture dot it Staff
Maxwellrender dot it Staff
____________________________
www.segnoprogetto.it
Top
 Profile
Search for:
Jump to:
