Maxwell Render
It is currently Fri May 24, 2013 6:20 am
Post new topic Reply to topic  [ 13 posts ]
Author Message
PostPosted: Wed Jun 06, 2012 3:23 pm
Anyone have an idea of how to go about making a marble material that has some subtle SSS, as well as deep refractive cracks? In other words, cracks that you couldn't feel with your finger, but would perceive visually? Polished marble tends to have cracks that you can see but not feel.
Render time is not a concern, hit me with your most contrived solutions...
(My hunch was a simple 2-layer material: color on BSDF #1 and transparent glossy BSDF #2 with a deep normal map for the cracks? Then turn on SSS for #2?)
_________________
Matthew Spencer | Jeff Koons Studio
Top
 Profile
PostPosted: Thu Jun 07, 2012 4:05 am
You can do volumetric cracks using geo which is only visible to refl/refract. That geo needs a special mxm which is just a coating with the bsdf turned off. Tom's idea originally.
And you can try texturing the trans of your sss, but you wont get truly veiny volumetric effect thats impossible. The first image uses normal maps on the metallic flakes which helps them look submerged, esp for animation.
_________________
Materials, Arch-viz, C4D Dynamics
Top
 Profile
PostPosted: Thu Jun 07, 2012 5:36 pm
Eric, thanks for the response, very helpful. Unfortunately I can't model in any cracks. This particular project requires the reproduction of a real-world marble from a vendor. The resultant renders will be used basically as "preview" or demonstration images, shown to potential buyers, to give them an idea of what the finished sculpture would look like. As such I need to be able to tweak and/or move around the cracks on the fly, so that we can fine-tune it to get it looking accurate.
Here's my start so far, without SSS. As you can see, the cracks are extremely unconvincing. They look more like soft stone cracks than marble veins. EDIT: image has been overwritten, no longer relevant
If you're feeling tremendously helpful, here's my MXM package:
https://dl.dropbox.com/u/2569505/Pink_Marble.rar
Thanks again for the advice.
P.S. - I couldn't find your normal-mapped flaky material in the resources database, would you mind making it available for me to reference for my own material?
_________________
Top
 Profile
PostPosted: Thu Jun 07, 2012 11:37 pm
Because of that you dont need to boolean just overlap the geos, so not much modelling.
I'm sure your client would be happy with a photo-textured mxm, normal maps manipulate the surface normals so cant help with volumetric veins / cracks.
Put the same texture in trans slot with default sss, and set assym to -.5 or thereabouts, that should do it, but it depends on the mapping too.
_________________
Top
 Profile
PostPosted: Fri Jun 08, 2012 2:15 pm
This is great.
Just a question, when you say overlap geometry you mean that you are completely modelling every piece as "joined" (so you have 2 faces overlapping but with opposed normals)?
And just this overlapping parts has got what only refl/refract material?
Thank you,
Rickyx
_________________
Linux Ubuntu 11.10 Oneiric Ocelot 64 bit, Kernel 3.0.0-20-server, Gnome 3.2.1
Intel® Core(TM)2 Quad Q6600@2.4GHz - 8Gb
Windows Vista Home Premium
Intel® Core(TM)2 Duo - 4Gb
Top
 Profile
PostPosted: Fri Jun 08, 2012 5:38 pm
No.. cracks are single sided geo..., Its just that you dont need to worry about modelling cracks to fit the geo, the thin bumby 'crack' geo just has to intersect the transparent object, then it becomes a visible crack.. you see.
So you can animate the cracks if you want... :)
And Ricky there are no 'pieces', the visible transparent object remains unmodified.. which makes this quite useable.
To all: For a general guide to faking marble veins, this mxm is a good start.
EDIT:fixed the link
http://www.mediafire.com/?6vcx7q99dkid9z1
_________________
Top
 Profile
PostPosted: Sat Jun 09, 2012 12:12 am
I'm having at go at what I recommended (only fair :) ), and so far so good, heres a wire. I used a voroni fracture to model a honeycomb core (shown in white), but I'm also testing the crack technique, in the screenshot this is the lumpy plane geo.
sl13;
one more sl17;
_________________
Top
 Profile
PostPosted: Sat Jun 09, 2012 3:55 pm
Awesome Work Eric! :D
_________________
Tea_Bag's Maxwell Gallery: viewtopic.php?t=29110
Portfolio - http://www.dvc3d.com (Under Construction)
Texture Packs - http://www.dvc3dtextures.com (Now Live)
Top
 Profile
PostPosted: Sat Jun 09, 2012 5:41 pm
I wouldn't bother with the honeycombe, its slowing down the render too much, perhaps a few submerged pieces near the surface is enough..
honeycombe is creating those dark marble flecks in this render, (doesnt have to be dark, could be any colour)
So yeah beware the honeycombe thingy is very inefficient, 'dont try it at home kids' :)
However the white crack technique is quite useable (I ended up with a live boolean so its still animatable, but doesnt show up in the marbles topcoat reflection), I just made it hidden to cam in case it intersects the surface due to the displacement...
_________________
Top
 Profile
PostPosted: Sun Jun 10, 2012 1:18 am
Brilliant, this is materials beastery
_________________
Top
 Profile
PostPosted: Mon Jun 11, 2012 10:57 am
wow brillant really!!
Is it possible to share this mxm Eric?
thanks a lot
Top
 Profile
PostPosted: Mon Jun 11, 2012 11:36 am
The marble is nothing special, just 1 bsdf, and the Vein.mxm can be made in many ways, the key is that it doesnt have transparency and is single sided geo.
vein;
_________________
Top
 Profile
PostPosted: Mon Jun 11, 2012 1:14 pm
thanks eric for the detail
Top
 Profile
Search for:
Jump to:
