These are free MXM sets made for the Arroway textures sets of the same name -- these MXM's will not work without the appropriate textures, which can be purchased at
http://www.arroway-textures.com/Directions for using these MXM files:
1) Unzip and place the MXM files into the same folder(s) you have the unzipped Arroway textures.
2) The full-rez MXM sets will only work with the full-rez (png) textures... these will most likely not work properly with the free sample Arroway textures you get when you purchase Maxwell as they are not necessarily the same images/resolution.
Please note: there is absolutely nothing that qualifies these textures as the ideal representation of what the Arroway textures are meant to be (there is no such animal) -- these are simply a version designed to save you some time and give you a starting point, therefore you are highly encouraged to modify these MXM's to suit your personal taste and needs.
Wood-1_RealScale full-rezWood-1_Relative-Tiling full-rezWood-2_RealScale full-rezWood-2_Relative-Tiling full-rezWood-3_RealScale full-rezWood-3_Relative-Tiling full-rezWood-Flooring_RealScale full-rezWood-Flooring_Relative-Tiling full-rezConcrete-1_RealScale full-rezConcrete-1_Relative-Tiling full-rezTextures Edition-1_RealScale full-rezTextures Edition-1_Relative-Tiling full-rezTiles-1_RealScale full-rezTiles-1_Relative-Tiling full-rezStonework-1_RealScale full-rezStonework-1_Relative-Tiling full-rezAlso, during testing it was found that the naming conventions of the Arroway textures have changed at some point in the past (adding extra zero's, etc.) and users who have purchased older versions of these sets may find that some MXM's do not automatically find their textures -- the remedy for this is to use
FastStone to rename a copy of the textures (keep the original versions unaltered in order to preserve links to any pre-existing materials you might have).
I would like to particularly thank both Arroway and Next Limit for their assistance in the creation of these sets.Best,
Jason.
