Maxwell Render
It is currently Mon May 20, 2013 8:16 am
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Author Message
 Post subject:
PostPosted: Thu Feb 07, 2008 7:14 pm
I use these packages:
GLIBC 2.5 version:
maxwell64-1.6-fc6.tar.gz -- Maxwell Render 1.6
Maxwell Render 1.6 (Linux 64 bits) glibc version: 2.5 (84,59 Mb) Nov 28 07
next I patch with this package:
maxwell64-1.6.1-exes.fc6.tar.gz -- Maxwell Render 1.6.1
Maxwell Render 1.6.1 (Linux 64 bits) glibc version: 2.5 (11.31 Mb) UPDATED! Feb 04 08
:wink:
Top
 Profile
 Post subject:
PostPosted: Thu Feb 14, 2008 10:11 am
Finally all new nodes are installed and are running together with the windows nodes!
I'm running a Benchwall 1.6 test now will post the result when they are done...
Here are the results:
Linux64 machine, dual Quad Core 5345, 2.33ghz, 4GB ram:
SL:15, Benchmark: 677,239, 16m06sec
win32 machine, dual Quad Core 5335, 2.0ghz, 4GB ram:
SL:15, Benchmark: 804.126, 13m21sec
Tom where in the pipeline is the optimization of the linux version?
/ Patrik
_________________
Application & OS: [Microstation V8i][3dsmax2010][Maxwell][Vray][Vue8][Win7-64bit]
Workstation: Intel i7 965 extreme 3.2ghz, 12GB Ram
Renderservers: 8xCore2Duo's E6600, 8GB Ram, 3xDual Quad Core 5335 8GB ram, 3xDual Quad Core 5345 8GB ram
Top
 Profile
 Post subject:
PostPosted: Thu Feb 14, 2008 1:34 pm
We will have good news. :)
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Thu Feb 14, 2008 1:57 pm
When ?? :P :P
_________________
Top
 Profile
 Post subject:
PostPosted: Thu Feb 14, 2008 3:50 pm
http://www.maxwellrender.com/forum/view ... hp?t=27319
:wink:
_________________
En la vida solo hay dos cosas seguras: la muerte y los impuestos.
gallery: viewtopic.php?t=13820
http://www.foto-viva.es/
Top
 Profile
 Post subject:
PostPosted: Thu Feb 14, 2008 4:15 pm
Damn how could I miss that :)
Downloading!!!!
will do new benchmarks tomorrow
_________________
Top
 Profile
 Post subject:
PostPosted: Fri Feb 15, 2008 8:58 am
OK just finnished the Benchmark!
This is my results now!
SL:15, Benchmark: 768.702, 13m58sec
Thats a great improvement!
_________________
Top
 Profile
 Post subject:
PostPosted: Fri Feb 15, 2008 9:08 am
I'm rendering in Co-Op as much as I can atm to see if I can find some bugs :)
I'vge seen some strange things, for example, I've had the "not enough licenses-issue" once, restarted the rendering and it rendered fine though.
I've also had the problem that MXCL crashes when it tryes to start a render.
Last time that happened I restarted mxcl on that node, and it crashed again at the same time. Restarted it again and that time it started to render?
Ill test more until we call it a bug though :)
_________________
Top
 Profile
 Post subject:
PostPosted: Fri Feb 15, 2008 12:13 pm
If I render the Benchwell scene in Co-Op mode I get another result... the linux nodes are faster (Pathera, Mustang, Corvette):
_________________
Top
 Profile
 Post subject:
PostPosted: Fri Feb 15, 2008 6:36 pm
Many Thanks to Next Limit for this wonderfull upgrade.
It's fantastic !
Thank you very much.
Top
 Profile
 Post subject:
PostPosted: Tue Mar 04, 2008 3:37 pm
tom, I've seen that textures are loaded fine at the Linux nodes, but it cant find the IOR files. UNTIL i put them inside the texture-folder.
_________________
Top
 Profile
 Post subject:
PostPosted: Tue Jun 24, 2008 1:53 am
Now, it'd worth to check this again. ;)
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Tue Jun 24, 2008 11:49 am
Yeah well, my 13 rendernodes are back to Win64, with licenses and everything. So my linux-train has passed for now I'm afraid...
_________________
Top
 Profile
 Post subject:
PostPosted: Tue Jun 24, 2008 12:42 pm
OK, then let me give the good news. Now in my benchwell tests, Linux version is 13% faster than Win version. :wink:
_________________
Next Limit Team
Top
 Profile
Search for:
Jump to:
cron
