Maxwell Render
It is currently Sun May 19, 2013 7:42 am
Post new topic Reply to topic  [ 8 posts ]
Author Message
PostPosted: Thu May 24, 2007 1:17 am
Before I do anything stupid. anyone manged to install this in ubuntu feisty7.04
I am having some troubles
I get the folowing error when trying to load studio
Xlib: connection to ":0.0" refused by server
Xlib:
Invalid MIT-MAGIC-COOKIE-1 key
mxst: cannot connect to X server :0
Top
 Profile
 Post subject: UPDATE
PostPosted: Thu May 24, 2007 3:59 am
ok so I finally got somethings working , but now I think taht my fiel is having some problems this is what I get notice that I ge tno icons and I can;t get the material preview window and who knows what else I am not getting. I get the following error.
QPainter::begin: Paint device returned engine == 0, type: 3
QPainter::setCompositionMode: Painter not active
QPainter::end: Painter not active, aborted
QImage::scaleWidth: Image is a null image
QPixmap::fromImage: Cannot convert a null image
QPixmap::scaled: Pixmap is a null pixmap
QPixmap::scaleHeight: Pixmap is a null pixmap
can't open //images/griduv.jpg
and here is the image
http://www.flickr.com/photos/40322284@N00/511562786/
Top
 Profile
 Post subject: ubuntu feisty amd64
PostPosted: Sun Sep 09, 2007 12:53 am
Yeah, same symptoms here.
Code:
deoli@untxi:~$ cd /opt/maxwell64
deoli@untxi:/opt/maxwell64$ sudo ./mxst
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
  Major opcode: 14 (X_GetGeometry)
  Resource id:  0x0
License file is invalid!
X Error: BadPixmap (invalid Pixmap parameter) 4
  Major opcode: 93 (X_CreateCursor)
  Resource id:  0x0
X Error: BadCursor (invalid Cursor parameter) 6
  Major opcode: 2 (X_ChangeWindowAttributes)
  Resource id:  0x2a002b2
And I get that last line when I try to Register... Plus when I quit Maxwell Studio, ubuntu chrashes and I'm back at the Login screen. And when I sudo ./startmxst I'm back at Login directo.
Top
 Profile
 Post subject: compiz
PostPosted: Sun Sep 09, 2007 3:26 am
Hey do you have beryl or compiz installed. I remeber doing a couple of things and then it work. I can;t remeber what was one but I had to chage some setting because of beryl
Top
 Profile
 Post subject:
PostPosted: Sun Sep 09, 2007 11:15 am
Works fine here together with Beryl/Compiz on Fedora Core 7 x86_64, you just need to change Alt+LMB key combination to Super+LMB in Window settings.
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Thu Sep 20, 2007 11:40 am
Thanks for the tips.
I was actually running Compiz when I had the problems I described. I tried installing/running Beryl - but after a couple of days with no success I gave up and decided to install Windows.
BUT - same problem! IE when I start Studio in Windows a message appears about Material Preview not being available and then a very dismal looking Studio opens up with no icons and only the 3D view window - exactly as in ubuntu. Which means either a) Studio won't run on my hardware (M2A-VM with integrated ATI graphics), b) the official ATI drivers suck on Windows as much as on Linux or c) I've lost my marbles.
Back in ubuntu: concerning the license everything's fine now, I had to of course copy the DAT file and not the TXT :roll: - at least it's accepted when running mxcl, mxst still gives the same error. But I don't really need to run Studio on this box anyway, what's more important is the Maxwell server. But when I try to start it I get the same as what Aji posted earlier:
Code:
Object::connect: No such slot CnetServer::socketError(QAbstractSocket::SocketError)
Top
 Profile
 Post subject:
PostPosted: Thu Sep 20, 2007 12:17 pm
Well, compiz / beryl / compiz fusion will always tend to cause problems with applications using 3D OpenGL viewports. I tested Maxwell on Ubuntu 7.04 x86_64 and it works very nice. Although the machine has onboard Intel graphics I only had to disable viewport antialiasing. So, your ATI card could be highly responsible about the problem. About licensing, yes you need to get rid of txt and place dat file. On the other hand the error with mxst is not about license I guess. When mxcl accepts it, it means it's also OK with mxst, too. How do you start mxcl server btw?
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Thu Sep 20, 2007 1:32 pm
To start mxcl server I made a copy of startmxcl, named it startmxsv and replaced -d with -server.
Top
 Profile
Search for:
Jump to:
